It sounds like you're covered then. Beware the trees when you get your replacementI still have one more replacement left from the care refresh program....
Although sometimes you can use sports mode to get amazing footage you couldn't get at normal speeds...Remember, it's a flying camera, not a building surfing, tree splitting, freestyle drone racer.
Sport mode is (in my opinion) for getting you home in an emergency (like higher winds aloft).
Thanks, I hope so too...Ive seen alot worse. Hope youre flying again soon.
When you get your replacement, try turning off your anti-collision sensors and you will get a speed between P and S mode without the over-sensitive stick inputs of Sport mode. Also remember the pause button on the RC. It is like an emergency brake and is the fastest way to stop. I stuck a small button on mine to make it easier for my thumb to find it.Although sometimes you can use sports mode to get amazing footage you couldn't get at normal speeds...
Try it. The Mavic will almost stand on end to stop. It also cancels stick input for a couple seconds in case your fear-induced fingers are still pressing one.Hmmm, I haven't used that button before...
First of all, sorry this happened, but having watched your videos, I appreciate your willingness to fly so close to the treetops.Although sometimes you can use sports mode to get amazing footage you couldn't get at normal speeds...
