I have an idea...
Garuda
How cool will it be to send up your Mavic for a POI-rotation, around a significant object in your own town. Write down your target focus, height, distance and rotation speed/direction. Do this 4-times/year and film this during four seasons and cut it together while in rotation. I will do this myself and post the video here on MavicPilots. Maybe a silly idea but I think it would be worthwhile :-)
How cool will it be to send up your Mavic for a POI-rotation, around a significant object in your own town. Write down your target focus, height, distance and rotation speed/direction. Do this 4-times/year and film this during four seasons and cut it together while in rotation. I will do this myself and post the video here on MavicPilots. Maybe a silly idea but I think it would be worthwhile :)
I think it is a very cool idea. Or you could do sunrise and sunset if you do not have the patience.
Reactions: Garuda
I believe it would look really cool if the four diffrent seasons are radically diffrent in appearence like here in Sweden. Very warm and nice summer, autumn windy/rainy and very colorful. Winter alot of snow and the spring just screams for the summer to come...This would be like a Timelapse-video on crack LOL
Reactions: Blades and TimO
Very good idea - exactly the kind of creative ingenuity this forum can really use.
Sounds like a whole new niche and drone-photography method (you should spearhead a new category on here; also develop the procedure and how-to for standardization for others to replicate.
Bravo sir - I look forward to seeing.
Reactions: Garuda
Completely agree - it's the patience and time going into this concept that makes it so epic, I mean it will be epic no matter what, but every time someone does a new shot or shares a project, it will spark major curiosity and intrigue.
1 - Go to an intresting area (building, tower, lake etc.). Record/write down GPS-location.
2 - Send up the Mavic to an altitude of preference. Record/write down altitude.
3 - Start POI-programming in DJI GO, and move away from target. Record/write down distance from POI-location.
4 - Center the camera on an easy to remember spot on object (same as before).
5 - Set the desired speed of rotation. Record/write it down.
Reapeat the process four times during the year and don´t forget to press record...;)
Then it just be some video-editing to make it EPIC...
Lichti will fly the same path over and over again if one saves the first mission around the object. Then just wait for the season to change and fly the mission again.
Reactions: MrsTreat and Garuda
Lichti will fly the same path over and over again is one saves the first mission around the object. Then just wait for the season to change and fly the mission again.
Never tried Lichti, sound very intresting! If you have your lift-off 50 yards from your previous location, will it find the correct location when it starts the program?
Yes. One defines waypoints and the place (waypoint at which to start recording). So for instance you take off 50 yards from where you want to begin recording. When you launch the lichti mission the Mavic will fly to the first GPS waypoint and orient itself in the direction you define in the Mission Planner. Then it will begin video recording if you have planned that in the mission. Then fly to the next waypoint while either pointing itself towards the next waypoint OR slowly interpolating its orientation to the next waypoint and direction it should be pointing. (its a really cool feature to have the mavic pivot its camera smoothly between waypoints) Its hard as a manual operator to have every bit of the pan be smooth as silk as fingers on controllers are only so accurate. The mission uses exact GPS waypoints so they are pretty darn accurate and are flown AUTONOMOUSLY. So even if the Mavic looses signal to the controller the mission is still flown from start to finish.
Of course your last waypoint should be setup in the mission to be close to your take off location so the bird will fly back to you and allow you to take control and begin the landing process.
Go to Mission Hub - Litchi Create an account under Missions} New to begin creating missions.
Its the mission hub that allows one to plan missions. Then check out the Phantom Film School link in the lower left hand side. Its free to view and experiment with. If one wants to download the missions to thier chosen device to actually fly them then they will need to pay for the Lichti App. Its on the Play Store and I think on the Apple Store as well.
The beauty of this approach is being able to replicate with great accuracy a flight that has been flown in the past. By saving the mission and reflying it.
Reactions: Garuda
Will definitely check this app out! Still a bit sceptic though, how accurate it will be (GPS-location, camera angles etc). Will give it a try!
Build a short "mission" to easily use the same position.
Reactions: Garuda
Sitting right now messing around with Litchi, so far seems awesome! Will try it out as soon as this "storm" here settles.
Old fashioned as I am I am trying to do this manually. Just log what altitude, distance and speed/direction rotation is and trying to go from there...here is the first shoot (winter). Bohus Fortress (Sweden, Gothenburg).
Reactions: BerndM
I use Litchi for this and it works great. I suggest that you pause the mission just before you start recording to check the focus, exposure, white balance, and other settings since the scene will be changing with the seasons.
andyt19852
