Hi ff22
Very strange
I get this message to
I click yes and SC was restarted
And I do not see this message any more
Also did you notice now you do not need relink SC if you want use it with other Mavic 2 drone
Mavic2 now hold multiple link info
I have Mavic 2 Pro and Zoom
And this option very cool
This time it looks like it worked.
Since I only have one drone, the linking of more than one drone does not affect me but maybe I should take advantage and buy a second (g). I will wait for the Mavic 3!
I certainly hope that the sd card is not treated as what was/is called Adoptable storage which blurs the lines between Internal and External (sd card) and makes it impossible to remove the card and read it elsewhere. I will have to check later as I have a meeting in half an hour. I just want to store stuff there but not blend/meld or merge them as one.there is other glitch there i think. when you say yes - it mounts it as a part of internal storage - moves all the data files to the sd card, it is good.
but, if you look at what then happens when you alter storage options - it alters paths of how photos and movies would be stored, and i think it is not quite correct. so, right now i think i get movies and photos stored on the sd card correctly if config options to store on the sd card are disabled. in fact. would need to play with it more, but, have no time now.
you definitely cannot pull out card anymore while SC is up and running, after it is set for the storage option. but, all the rest works fine. i like i this way much more - it is very easy to get flight logs now, just get the card out.I certainly hope that the sd card is not treated as what was/is called Adoptable storage which blurs the lines between Internal and External (sd card) and makes it impossible to remove the card and read it elsewhere. I will have to check later as I have a meeting in half an hour. I just want to store stuff there but not blend/meld or merge them as one.
