Sorry, maybe I am missing information.
do they have problems with the IMU current settings or with the calibration process?
Btw: how many are "so many"?
yes and at the Phantom series i use to pop mine in the fridge before cali. Also leveled surface is needed. Cold cali will save u warm-up time at AC startup.I have a question on a IMU, is it better to calibrate the drone as quickly as you can before heats up? or does it even matter? i been seeing people talking about this
If all your flights have been problem free and your calibration status is good then you're on the right path. Always check the calibration status before each flight.Had my mavic since early February, all updates done, have not calibrated anything because I thought it would tell you if it needed. Have not had the first problem yet. ( YET)
