Intelligent Battery Charging Routine For Mavic Pro
AbUAVdC
Worldwide
You’re Mavic Pro Battery still charging and kicking for years! How did you charged them to get that far?
I charge the Mavic Pro Battery between 10% to 30% and remove from cradle when reached 100%
I only charge mine to 50-60 percent and the rest of the way if I need them - so they are stored at 50-60 percent - only to 100 percent if I need them that day - always stored above room temperature - I try to not recharge them till they come back down to room temperature.
Reactions: WAXMAN
Stored above room temperature intentionally? Lower temperatures provide for longer lifespan.
Stored at room temperature I meant as per the manual - above 20 degrees or so
Don't worry about the packs going below 20deg C in storage. It is better for them. Deliberately keeping them warmer is a total waste of effort with no benefit.
Reactions: AbUAVdC
explorjus
