I am currently using the iPhone 6sPlus and have no issue. Just sometimes have to deal with a whole lot of pop up messages that makes it hard to see the flight. Felt like I need a bigger screen.
I have an iphone 6 plus 128gb i use as a dedicated device for flying..all apps deleted, and other apps I cannot delete are turned off. Works very well.Thanks all, so I guess no problem with Iphone 6s+. I didn't put the phone on airplane mode to get map data but I did turn off wifi.
Now that I've got coffee in me I remembered I still have my box next to me - the box does literally say on one of its ends "Designed for iPhone" with a list of devices starting from the iPhone 5S up - including the iPhone 6S+. Chances are it's interference - when you're having these problems if you go into settings it should tell you the signal strength for the channel you're on: (image blatantly stolen from Lastrexking here)
Having a lot of interference will degrade both the live video quality and the RC connection so it's always better to fly with lower interference.
So it’s possibel to use and iPhone 6s Plus with no service as controller? I’ve heard an iPad mini doesn’t fit the air remote. I would also like to have it in a life proof case as I’ll be out in the middle of nowhere tough environment.I am using an old OnePlus Two (my backup phone with no SIM in it) as my screen. It has no applications other than the DJI Go 4 app installed on it so there is no chance of being interrupted. Had no issues with it at all in terms of performance, WiFi drops, etc - even in comparison to my new phone (OnePlus Five) which is obviously superior in terms of performance.
Will an iPhone 6s Plus in a life proof case fit the remote or will any lifeproof case be to thick? And thank you for all your help! Any other suggestions for small tablets ect or large phones
You be the judge. The arms look like they will take 9mm thick item - maybe you can squeeze something a bit thicker in. The connector can be moved, so don't worry about it.Will an iPhone 6s Plus in a life proof case fit the remote or will any lifeproof case be to thick? And thank you for all your help! Any other suggestions for small tablets ect or large phones
Have you tried that? They don't appear to slide out like the rubber grips in the Mavic Pro remote controller.You can remove the screws for the rubber grips, remove the rubber, then you might be able to use your case too.
I fly the Air with a CLEAN iOS install. I have a dedicated iPhone 6+ that is not even on a cell network. I use it with WiFi only.
