Is this noise or a sensor issue?
Looks like noise. ISO 1600 is a lot for the small sensor...
It's just in the pitch black parts of the image
Reactions: halley
Took some low light shots and noticed this strange noise on the raw image. Anyone had a similar experience, or know if this is normal? It was shot as f2.2, ISO 1600, 1/3s and 4.7mm.
I saw that myself not long ago. It ended up being the graphic card getting to stop working on your laptop/pc. I took my laptop apart and cleaned it, then did the heat gun trick and it was like brand new again. I would recommend you at least start looking into backing up all the important stuff on the pc.
Yeah I find that above 800 ISO the camera struggles.
It might be just me but I prefer shooting from 100 to 800 max, yes you would need some ND filters in order to shoot in different light conditions.
How a JPG or PNG or MOV gets recorded on the Mavic has nothing to do with your PC. This is a screenshot, yes, but the sensor noise is much more likely here. Interesting idea but completely independent.
I figured it was noise I've just never seen anything like it shooting on DLSRs but I've also never shot with a sensor that small so that does make sense.
Well thanks for the heads up, I'm on a 2015 Macbook Pro but stranger things have happened so I'll look into it.
I'm so used to shooting with DLSRs and ISO 1600 being perfectly acceptable so I guess I've gotta switch out of that mindset. I realized this sensor is great in the day but not so hot during the night, I wonder if I increased the shutter time instead of ISO if it would still happen?
I think the camera is quite acceptable at night but yeah try lower shutter speed with lower ISO.
I think I took that pic in full auto and there is tons of noise.
Will do some tests tonight.
Your Macbook is new enough that it's not doing what I had experienced. When I 1st saw the noise I it remided me of what I had dealt with not long ago.
SLRs have similar behavior where above a certain ISO the dark zones turn into muddy purple noise... but it's simply typically several stops higher.
Vakilkaro
