I'm going to see if they help with VLOS in the daytime.
It's recommended two on the front.
I chose white.
Can't wait to try them out.
I figure if I loose sight and/or video feed I can spin it until I see it facing me.
do you have the link please where those are available, along with those mountsI'm going to see if they help with VLOS in the daytime.
I chose white.
not available on Canadian Amazon either,Get a set of ARC2s.... somehow, maybe Amazon.... you won’t be sorry. In the AZ sun midday I can easily see them 1-1.2 miles away and at dawn or dusk it’s more like 2-2.5 miles. Above is based on looking away at the controller and requiring VLOS. Younger eyes may do better.
Get a set of ARC2s.... somehow, maybe Amazon.... you won’t be sorry. In the AZ sun midday I can easily see them 1-1.2 miles away and at dawn or dusk it’s more like 2-2.5 miles. Above is based on looking away at the controller and reaquiring VLOS. Younger eyes may do better.
Maybe a seller here can chime in and direct us how to acquire them outside the USA
I e-mailed Firehouse, told them what I wanted but couldn't order through their website, they put together an invoice through Paypal, and sent that to me, so I paid and the strobes and mounts are on their way. Send them off an e-mail. Great bunch and very accomodatingSaw the Arc 2's, yes tha'd probbly do me fine.
I only want them to keep me in VLOS as per Australian regulations, I just lose sight of it if I loko away for a second or two, very hard to then find it again.
That'd be nice
I'd be happy to email credit card info over several messages (for security), then it's just a matter of posting those in a padded envelope, very small expense.
I'm happy paying around the US$100 to $120 for a set of 4, 2 white and 1 each green and red, plus post etc.
Let me know what you think of them when you get them pleaseThanks Torcan, will do that.
I'd rather buy direct from them too.
Sometimes the systems in place on e-commerce sites just isn't set up for international, but there is a work around.
Cheers.
Agree with you on direct purchase. You’re gonna love them!Thanks Torcan, will do that.
Cheers.
Went flying today with a new friend from here. We were taking sunset pics... he commented several times about how he cold see my M2P very easily at well beyond a mile. Best part for me was that my Aerial Pixel mounts, while tight, worked with the new version of PolarPro M2 landing gear.
The Aerial Pixel mounts come in two styles, at least for the M2 series and the reason; one for rear arms and one for front legs with right and left sides bring mirror images since they mount on the legs (landing gear). The options can be seen on the site. The strobes point straight out in front.Cheers Thomas, I bet they will be very much part of standard flying once I start on them, they certainly look the best option . . . especially bang for buck on light output vs weight.
It looks like that supplier seems to carry the mounts only for the single and arc dual Firehouse lights ?
Tell me, I looked at Aerial Pixel website and the mounts, they are flat, not like the angled ones in the OP by TedShred ?
Not 100% sure, but if fitting whites to the front, or green and red nav front and white on the back, I would think anything up front might interfere with the camera, and with flat mounts they would point in that way, with angled mounts it still might be a problem, hmmm . . .
Maybe the best option is to urethane a couple of velcro patches on the outside of the motor arms, so they are pointing sort of 45 degrees outwards ?
At the back it's no issue of course, could put them on the arms, or similarly on the motor housing, provided there is no obstruction problems.
DJI front leds go off when taking a photo or filming, there is a reason for that so maybe any mount on the front arms, or any light projecting more than say 45 degrees inwards is always going to be a problem ?
It might even be that 2 white lights on the back are the way to go, and rotate to find it ?
Some considerations to get through I guess.
I took sunset pics today with these holding my ARC2s, no visibility in my photos or videos.
I hadthe Firehouse version on the triangular type mount. I did not like them and took the strobes out to use as backups.
Yes! Spot on! I use 2 white ARC2s on the rear arms (one each arm) for better visibility... white is proven as the brightest and most visible color for them. Also since front arms have a red and a green in standard aircraft fashion it helps me visually know drone’s orientation.
Hope this helps.
