Learn from me, don't crash your Mavic Mini
ecolier
UK
Luckily it lived to fight another day - feel free to leave a comment.
Let me know how I can be a better pilot! ?
(And feel free to look at my other videos too :) )
well for a start you could be a better pilot by not flying so close to trees
not to mention the birds on the water, that would have been spooked by your drone if you had managed to miss the tree
Yep, I will pay very close attention from now on. That was not a suitable place to fly.
Perhaps I should have ascended higher straight from the take off point.
You flew into a tree! Trees are not your friend. Were you watching the drone? Were you watching the screen?
I was watching the drone, and not the screen.
Perhaps if I was watching the screen I would have seen how close it was to the branches!
You tried to be too daring, I see no reason to try to go between the trees. If you are inclined to try something similar do it in stages, move a little, stop, check the image, move as required, stop.................and if there is any wind stay well away.
Be wary around waterfowl.
Reactions: old man mavic
Indeed, I don't know what came over me to try and go between the trees. Or maybe use the C mode. Really should have just ascended and leave it at that.
may i suggest that you find a nice tree free field and practice your drone control by flying squares with the drone facing away from you
then face the drone towards you and see the difference that makes to how the drone moves in relation to the stick movement, practice flying circles then figure of eights and get used to how the drone responds to the stick inputs i know it sounds boring but believe me ,there will come a point when you get the hang of it ,and you will find that your flying becomes much more enjoyable ,even after several years of flying ,i will still find a quiet spot and fly a battery just doing the things i described, it helps to keep my muscle memory up to date ,and knowing how to make those movments has saved me from disaster on several occasions
Excellent suggestion, thank you!
Hey hey hey, tree was drunk and crossed the path of the Mini ?
Seriously, trees don't move. Drone do. So best to always be conservative and careful in flying when doing those dramatic shots.
Glad to know that your Mini lived to fight another day ... but don't fight a tree again. :)
With just a slight gust of wind trees DO MOVE.
I've used "grid lines" to help me estimate the holes i need between branches.
Reactions: Howard70
Use the cross hair which tells you precisely where the drone is going. At this point you should have released all the sticks and then apply forward stick only.
I read a post that the size of the crosshairs is also the size of the Mini.
An interesting idea but it would need an "at a distance of......." follow up. You can, after all, hide the moon with your thumb etc.
Reactions: scro
I think you've heard enough about flying around trees but I wish you had found a clear spot. That looked like and interesting area without the tree's in the way.
Reactions: ecolier
