lens problem
CHEN KAI
台灣
May I ask how to solve the fog inside the lens?
Use a hair dryer to fly it indoors and it will be fog again
Is there air running into my lens?
It looks like there should be some air running in.
I just bought it for 10 days and flew for less than 3 hours!
Thank you, I will try to do it according to the video..
How is it different from the movie? My God!!
Remove the stepped outer frame partially covering the lens and replace it with a third party UV filter. this takes the amount of light getting through to the sensor down by 1 stop, but also adds an extra optical glass cover which prevents fogging. Tried and tested.
Reactions: BurntFloridian
My outer frame seems to be glued together. I put it back together, and the amazing thing is that the far and near function seems to be broken. There is no action.. After taking off for 5 minutes, the lens will fog up. It's annoying!
Did you fly it in cold weather and bring it into a warm car or building shortly after. That will cause condensation.
No, it’s been raining for the past few days, so I’m flying indoors
I bought 17 days and the flight time is less than 5 hours
I read a lot of forum articles, and it is true that the lens is not completely sealed. This should be the same as the lens of the mobile phone!!
Meric
