Anyone here know a good drone simulator that can be use with the Mavic Air 2 controller. I've downloaded DJI Flight Simulator, but it doesn't support Mavic Air 2 controller.
In DJI FS, did you select one of the other AC controllers, I use the Spark one with the Mavic Mini and it works well.
It won't be an exact flight model but it works.
Have you installed and used DJI Assistant 2 for Mavic, that should install the relevant usb drivers for the MA2 RC ?
I haven't seen a simulator that's better than DJI FS at the moment
You could also try running the driver batch file from DFS itself
See this post
Mavic Mini and DJI Flight Simulator
Not sure if everyone knows you can use the Mavic Mini remote controller with the DJI Flight Simulator The Mavic Mini's flight characteristics are not yet simulated, but you can fly the Spark, Mavic Pro, Mavic P2 etc. The Spark is the closest simulation to the Mavic Mini The Mavic Mini RC does...forum.dji.com
Do I need to use OTG cable or any USB cable would do?
