lost 2 drones
are there any gps apps, or a compas i can use to get exact coordinates on ground?
Plug these coordinates into the map app on your mobile phone:
39.35976 -120.74110
Once you arrive at that spot, your Phantom should be in that area. If you don't see it on the ground, check up in the trees.
i used find my drone, and the line i was following was all over, i need Something that tells you move right move left ,10' ahead or some sort of Live satellite view where you can actually zoom in closer or see yourself walking around with a spot the tells you this is exactly where you need to go
If you do exactly what I suggested in this post above, you'll be taken to the exact spot where you need to start your search.
Reactions: Jasondronemaster
You asked and got post #22 and #23
Or you could get/borrow a handheld Garmin or similar.
kholik ibnu
