Low resolution RAW images
Hi All,
Does anyone know why Mini 2 dng images are much lower in resolution compared to jpg images?
dng resolution - 960 x 540
The 960 x 540 images are not .dng files at all.
They are embedded jpg preview files inside the much larger .dng file.
You probably don't have the proper software that can open .dng files .
Yes, indeed that was the case. First I checked the EXIF data using file properties in windows and then checked by mounting the Micro SD to mobile. Both showed the same result so I got a bit confused.
All sorted out now.
Thank you very much!
OkandaCreed Just realized that was your first post so
Hi & Welcome to Mavic Pilots.
You could try these free programs for RAW (DNG) Darktable download HERE or Raw Therapee download HERE
Thank you @THE CYBORG!
Indeed there has been some confusion since DNG files are a bit different from NEF files. NEF shows the actual resolution when checking the file properties.
Robby1983
