Lurker Finally Checking In
WShade
Texas
I joined a year ago and have been lurking ever since attempting to gain more knowledge ;). And, the knowledge runs deep on this forum so thank you. Well, my Air 3S arrived today so I am finally checking in from San Antonio! 👋
"the knowledge runs deep on this forum so thank you."
What?
I been on PPF since 2015.
These forums, are #1.
Members are great, I'm not one of them. :)
The moderators are also great Thumbswayup
I learn a lot from these.
Rod ..
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members who are willing to help you with any questions you might have. Search the forum using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response!
Fly safe and stay safe!
Welcome back from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic Air 3, including the User Manual.
Fly On and Fly Safe…
jdcleland
