M2P Precision Landing is gone?
zeusfl
Mavic Pilot Guru
Florida
Site
youtube.com
As you guys probably know I just got my M2P yesterday. Today I was trying to land my drone in the landing pad by RTH and is landing very off the home point.
I search online and there was a precision landing option but I can not see this option in my app. I am using a landing pad, daylight with all the requirements for precision landing.
Does DJI remove this option in the M2P?
Thank you very much. I should search before asking the question. Thank you again.
Reactions: dirkclod
RTH precision landing performed by my M2P. The take off point was the corner of the white markings . Note how the drone made the last-minute correction as it approched the ground :
Reactions: zeusfl
I have had my M2p, since release. and it is on point when it comes to landing.
So far I have about 20 flights in my M2P. I can safely say my Mavic Mini is a more precise landing than the M2P. The M2P miss for up to 6 feet on distance from the landing spot and i am using a landing pad. The mini miss for up to 2 feet.
I know this is impressive from the mini but is a newer drone. There is a lot of room to improve.
My M2p lands on point everytime. Is your bird up to date as I thought there was a go 4 update that resolved this issue a while back.
Reactions: Mavic 57
I got it brand new 2 days ago. Fully updated before fly. I will reload the firmware with the DJI Assistance 2 and try again.
you need to take off and hover in place 3-4 feet off the ground for a short time before you start flying. it needs time to picture the ground under it
Reactions: Mavco
Sorry for my ignorance, does the M2P take the picture with the main camera or the camera sensors? Do i need to point the camera down?
Not the main camera one from the bottom.
Reactions: zeusfl
It works !!!!!!! the trick is as soon as I took off accent 14-18 feet and hover there 10 seconds. Now works every time if I do that.
Thank everybody for your help.
Just click auto takeoff .. let it got up and hover for 5s to record its takeoff point.
Whenever I start my M2P (smart controller) I do not see an auto-takeoff button. Instead, there is an autolanding button. (I know, doesn’t make sense.) I don’t remember if it started out this way, but it’s been this way for at least 8 months.
i start with CSC. Is that the problem? Is the auto takeoff there before that? I flew today and noticed the auto landing on startup but didn’t look at it before the CSC.
I agree - that's what I do and never had a problem landing back to the same spot. Try it and see what happens. Happy Flying :)
I was just going to say it's all in the takeoff and yes using Auto takeoff letting it over for a couple of seconds at least there will lock-in location take its little picture and be able to bring it home pretty **** accurately
Actually the hovering is not necessary. What need be ensured is that you go straight up to over 7 m or about 25 feet before flying horizontally. You can go up as quickly as you like
Reactions: zeusfl
instaproapk
