Just a question what I should have done better.
I made a very short flight in town to end the day.
The problem was that my MA2 when returning home stopped next to me just 2 m above the ground
and after that I couldn’t make any movement: not up, not down, not forward, backward etc. After trying to switch it off, the only thing I could think was to grab the MA2 (motors were running like crazy when I hold it) and at the end pushed the button on the battery to switch if off.
Some info:
Some info:
Flight time | Altitude | Home Dist | Type | Notification | |
A | 00m 00s | 0.0 m | 0 m | Mode | Mode changed to Motors_Started |
B | 00m 00s | 0.0 m | 0 m | Tip | Setting new Return-To-Home altitude to 38m (125 ft). Data Recorder File Index is 34. |
C | 00m 01s | 0.0 m | 0 m | Mode | Mode changed to AutoTakeoff |
D | 00m 04s | 1.0 m | 0 m | Mode | Mode changed to P-GPS |
00m 12s | 2.8 m | 1 m | | 30% Battery | |
02m 00s | 64.3 m | 65 m | | 24% Battery at maximum distance | |
02m 53s | 49.8 m | 29 m | | 20% Battery | |
E | 04m 01s | 3.1 m | 8 m | Mode | Mode changed to Go_Home |
F | 04m 59s | 0.6 m | 2 m | Warning | Not Enough Force/ESC Error. Aircraft max power load reached. Decrease altitude and fly with caution. If this issue persists, land immediately(Code: 30168) |
G | 04m 59s | 0.5 m | 2 m | Warning | Not Enough Force/ESC Error (repeated 50 times) |
