Hi all, having a bit of an issue getting the 4K content to play on my laptop, I’m using a VLC player Which I’ve tried to adjust to play 4K to no avail, so I’m wondering if I could play the content direct from the drone to my 4K tv using the supplied data USB cable. Any thought would be much appreciated.
I only have M2P but hopefully it's same with MA or MA2. My manual says it's okay to directly connect the drone with a TV providing the TV has a USB port.
To play 4K video on laptop, you need to make sure your OS can decode H.265 and the hardware is powerful enough.
You may find that this is a codec issue (as suggested by @waynesi above). Most computer hardware will handle the H.264 codec - but H.265 is new on the scene and a lot of hardware/software will not handle it. Check that by changing the codec to H.264, and doing some filming than seeing if that plays OK. If so - you can then do some research to look at options ...
Thanks guys, wow this getting complicated, so the cable that comes with my magic air I can just plug this directly from the air to my 4K Panasonic and it should work or do I need to do anything else, sorry I’m not very tech savvy.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
