Marco polo
He's using the dig collar version of Marco Polo. I have the miniature one designed for RPA's and they don't add any appreciable weight or create aerodynamic problems. Same price for either version. I never put the bird up without it on for piece of mind. Simply Velcro'd to the battery.
I use a Marco Polo with each flight as well (waterproof version), even if just immediately above my location, in case of a flyaway. I also have multiple Mavics, so I needed something easily removable, yet I wanted something pretty permanent. The battery idea is fine, but with multitudes of those too, I'd be popping them on and off constantly. I also wanted something that wouldn't be an issue to pack in either a hardshell case or a backpack. Ultimately decided to go with it permanently affixed (Superglue and small zip-ties) to an extended landing gear mount.
Easy to pop on and off to switch between birds (or for charging if you need to move it somewhere else). Stable and doesn't affect flight (no noticeable difference for wind resistance/flight time, and no interference for any Mavic sensors or compasses). I realize it could separate upon impact/crash from the Mavic, but I figure if I could find the MP (Marco Polo), my MP (Mavic Pro) wouldn't be very far away. Been very happy with it for months.
Ide rather a trackimo. Cheaper and unlimited range as far as i can see and uses your computer or phone to track and you can find custom build holders or they come with a Velcro strap to attach no messy glue or anything like ypu were talking about
Reactions: moby_gr
The Trackimo is a nice option if flying in locations with cell service. I also like that it's possible to find the exact location of the aircraft on a map (instead of tracking it down with the handheld Marco Polo tracker). It's definitely not going to be cheaper in the long run though since there is a monthly fee to use it. The Marco Polo has no monthly fee since it only tracks with a radio signal.
The glue is not required and it is not glued to the device itself. I only glued the holder to the leg extension for even more security. The holder is secured to the leg with the included screws. The tiny screws though made me worry that it might work its way free over time. The Marco Polo device itself snaps in place (in its own holder) and can also be secured through zip-ties.Glue never touches the device at all (only the rear of the plastic holder).
I went with the Marco Polo over the Trackimo for three different reasons:
1) I often fly in locations with no cellular service or extremely limited service. Without a cellular signal to the Trackimo device, the tracking function is worthless. This is also true in a foreign country if you don't have cellular service on your device or in your own country if you don't fly with a cellular device (like using a WiFi version iPad). The 2-mile range of the Marco Polo is enough for me. I figure if I lose the drone, I can at least get within that range to initiate tracking.
2) Though the Trackimo initial outlay may be cheaper, it has a $60 annual subscription service required in order to function (which could increase in price at will). The Marco Polo has no subscription service needed. If I use the Marco Polo tracker for 2 years, it's roughly a break-even cost with the Trackimo. After that, it's even cheaper than any subscription service.
3) If the Trackimo company goes belly up in a year (not unknown for a tech company), the device becomes worthless, as you need their subscription service. If Marco Polo goes bankrupt tomorrow, my device keeps on working, even without their support.
This is just my point of view. I can certainly see the value in the Trackimo and other devices but for my situation, I decided to go with the Marco Polo instead.
Im choosing trackimo mainly because im not a traveler ill be in my area i live 99% the time and theres plenty of cell service and my fear is a fly away. A fly away can go alot further than 2 miles so i like the range better.
But it deff is what suits your needs more
I thought you were "Fearless"Robb... :D
Lmao well you got to look fear in the face to overcome it. Ill just be punching the fear with a trackimo on my fist lmao.
But on serious note if i looae my drone i cant afford another so then ill never get another for yrs so im trying my best to avoid loosing it
Interesting that Marco Polo now have a waterproof version. Mine isn't this one but I did drown the MP & Marco Polo - both under a metre of water for 20 hours. MP had to be replaced, Marco just fired up again after the obligatory few days in the rice bag. My picture of the MP with pontoons was just about me having some fun exploring this water landing approach. But what started off as fun has now turned into an amazing "over water" little bird. I have been using this over small dams doing many landings & takeoffs. Obviously I keep my speed down while skimming over the surface but as long as there's no appreciable wind it's as stable as. Trackimo would be useless to me where I fly. I also velcro on a small Drone Keeper mini onto the batteries which I've been thankful for a couple of times I've had the MP caught up in trees and couldn't see within the foliage where it was. I knew it was there because of the Marco Polo, but couldn't see which branch or which clump of foliage it was tangled up in. I don't treat my MP as sacred and fly anywhere hence my bright reflective decals and tracking/audible devices. Velcro-ing on these 2 units takes seconds and have never come off.
My Marco Polo is much smaller than what I see in the pic above. That might be the one designed for dog collars. Mine only weighs 12g and I attach it to the side of the MP with velcro. See the pics below.
I have never had to use it to find the drone but I have tested it by having someone hide it and then I find it with the handheld unit.
I realize the MP keeps track of last known GPS position, but I don't trust that it will be accurate enough to find the MP in all cases. My plan is to go to the area of the last known position and then use the Marco Polo to find the exact location. Assuming the MP goes down in a location that I can access, I am confident that I can find it if needed.
I just have mine attached with a small piece of velcro, on the top front over the camera. I don't have to remove it when I change batteries.
It's the newer waterproof version for drones. It only weighs 9 grams more than your version (23 gms total). I figured the fact that it would weather (pun intended) inclement climate if lost was worth the minimal added weight. Who knows if it'll rain before you can get to your drone or if it lands in a snowdrift. It gives me a bit more piece of mind knowing that if it flies through rain/snow/fog or it takes me 30 days to get to it, then the tracker should still be functioning. I'd hate to lose the drone with a tracker on it, simply because it got lost at sunset and it ended up raining overnight.
It too has shown absolutely no effect on flight or flight times.
Advanced RC Recovery Systems Archives - Tracking and Recovery Made Easy | Marco Polo the Tracking and Recovery System
I use the Communications Specialists PR100A tracker and 222MHz beacon. I fly in densely wooded landscapes, typically as Litchi waypoint missions and cell service is non-existent. Beacon is good for several miles LOS and a couple miles in terrain. Requires a ham license to deploy.
My RC version of the Marco Polo beacon just straps to the front-right leg of my Mavic with no modifications at all, using a couple of mini wireties. I never have to remove it, because the Mavic folds with it in place and it can be charged in place. Very simple and easy to do, and I think it looks a lot better than some of the clunky solutions I've seen around, but make sure the wiretie on the charging end doesn't interfere with the on/off button - the wireties are tight, so nothing shifts around in flight or in my carrying sling.
The MP's antenna will contact the ground if you don't use leg extenders as I do; these can also stay in place with a folded Mavic, so I don't have to fiddle with stuff preflight - just unfold and proceed.
Mike from PhantomHelp was noodling around with a design for a Marco Polo snap-on carrier (along the lines of his Strobon mounts) but hasn't yet created a product for sale.
Note: for those with the older, larger MP dog beacon, or the new larger waterproof version, you can just buy the new small RC beacon alone for about $100 and put the dog version on, well, your dog. The handheld tracking unit can handle up to 3 beacons at once.
Never fly without it, mine is velcroed because I use it in other drones.
fisterc
