re they worth the $30? Clearly quieter, but I read your get a motor error in sport mode. Anyone tried these?
Good to know. I will order a set. No sport mode errors?Yea I like them a lot. Not sure they are as quiet as the MPP props but they are better performance. You can get the black ones straight from Master Airscrew for $19.79 though. I guess unless you are outside the US then idk.
Oh they are absolutely worth every penny. The different tone they have combined with a significant reduction in noise make them a must have for me. Plus you can get them in bright orange for added visibility. I highly recommend them. I've had no problems in sport mode, altho I haven't flow in sport much with them.re they worth the $30? Clearly quieter, but I read your get a motor error in sport mode. Anyone tried these?
Good to hear I ordered a set. ThanksOh they are absolutely worth every penny. The different tone they have combined with a significant reduction in noise make them a must have for me. Plus you can get them in bright orange for added visibility. I highly recommend them. I've had no problems in sport mode, altho I haven't flow in sport much with them.
There's a rumour that MA are working on prop's for the M2Pro series. I saw a note late last year that said they were trying to get a new prop' out for the M2Pro in the first quarter of this year. They have just released the Mavic Air prop's - so have been focussed on those. MA seem to be very hot on providing a prop' that gives an efficiency improvement over the stock DJI version - and therefore, since the stock prop' for the M2P is pretty good - Master Airscrew may have a bit of a challenge!are the available for the M2Pro/Zoom yet...?
I don't have a picture but the visibility in flight is marginal. It is most apparent when flying close at eye level because of the aircraft tilt. Higher up there is very little difference. The better visibility I was referring to was on the ground or in a tree. I have not had to search for mine yet but the orange props definitely make it stand out against the greens and browns of foliage.Does the orange really provide much more visibility in flight? Can someone post in flight pics from the ground please? @Mossiback? @FoxhallGH?
I have a set of black MAS, but have yet to use them due to crap weather..
When the orange prop's are spinning, they are almost invisible and don't really add to the ability to see the drone in flight. They are an advantage however, if you are looking for a downed Mavic (that has accidently rough-landed in the wrong place - ) , as the stopped prop' blades stand out very well against natural foliage (except in Autumn I guess!).Does the orange really provide much more visibility in flight? Can someone post in flight pics from the ground please? @Mossiback? @FoxhallGH?
Yep.. I agree with everyone else. Doesn't help much in flight but will on the ground should the need arise.Does the orange really provide much more visibility in flight? Can someone post in flight pics from the ground please? @Mossiback? @FoxhallGH?
