Mavic 2 image transmission bitrate
Lucassssss
Stockholm
Hello,
I have a Mavic 2 pro with a smart controller.
Recently I´ve used the smart controllers HDMI output for television broadcasting by sending the signal to the outside broadcasting van.
The maximum bitrate I receive from the drone is about 10mbps in HD mode.
Is there any official or unofficial way to raise the bitrate?
I really need a better image due to television requirements.
Thank you in advance!
The Fly App call Smooth for the 10mhz or HD for the 20mz
The Go 4 App call it 10/20 but is the same concept. The lower is the less data needs to transmit making it easy to transfer in far distances. When you have the 20 or HD selected will have a better 1080p image but will require a solid connection in farther distance. That's why i use boosters to keep that solid connection without have to decrease to 720 image transmission in 10hz.
Reactions: Lucassssss
The drone itself is sending down a greatly reduced image size to reduce the bit rate required. As the WiFi gets weaker, the image further degrades.
Why I use an SD card in my M2P to be where videos and pics go. No degradation noted by me in the DNG+jpeg stills and my videos.
CMDR DV TEARDROP
