- Joined
- Jan 28, 2019
- Messages
- 41
- Reactions
- 33
This my first drone, I can't wait to get started! Thank you!!!!Wow - that's blue sky!
Under lower lighting, I haven't had much need for filters. When it's brighter I'll put on an ND filter so that I can keep a setting of 1/50 shutter speed at f/4 and not bottom out on minimum ISO. There are so many filters available. I have the DJI ones, but have used PolarPro ones in the past - they seem to have the greatest selection. There are also some less expensive options at the normal online sources. To date, I have had not much use for any polarizers - the wide angles don't seem to work well with them.
There is so much to learn and do - you're going to have a lot of fun.This my first drone, I can't wait to get started! Thank you!!!!View attachment 61274
Completed order on 01/22, shipped that same day. Arrived today 1/31. Was held up in customs, apparently this is a common issue. I contacted DJI first, with no help, just an apology email. I contacted FedEx and they responded quickly, and it was released from "Clearance delay-import" within 24 hours. So not bad coming from China with the customs issues!Very close to joining you with that combo..... how long from order placement to arrival was it for you?
