I just create my own cut file for air 2. Feeling free to use, good luck
As a pdf is the size accurate or do I need to adjust anything?I just create my own cut file for air 2. Feeling free to use, good luck
This is a bit off.
I'm quite sure there are better ways to do what I'm going to do...but...with my shallow computer expertise, I'm fine with it and don't mind the extra work. I have a friend that makes decals, so I will have him make 3 big squares, of whatever design I choose, using weather resistant decal material. I will then print out the actual size templates from @Mike.pham, carefully cut the shapes out and put them on top of my decal squares and trace them out with an exacto knife. A bit of a process, but as I said, I don't mind the little bit of extra work. Hope this helps in some way.thank you guys but i don't know how i start design through this template ? do you have tutorial on youtube how to desing on illustrator
metro graciasAcabo de crear mi propio archivo de corte para aire 2. Siéntete libre de usar, buena suerte
Thank you just what I was looking for, I can't download it on my phone I'll try again when I get home [emoji106]I just create my own cut file for air 2. Feeling free to use, good luck
