Not to mention adding 42 grams, far from center of gravity, and a cellphone transmitter right next to the bird’s sensitive telecommunications! Wowiee wow wow.I’d worry about it messing with the GPS or the compass.
That’s way better for flight dynamics!I’ve personally decided to go with the Loc8Tor Lite device. It works a little bit differently, but it’s much lighter, and combined with the Find My Drone feature should be enough to easily track down a lost drone.
You make a very excellent point. My plan was to mount it on the bottom, away from the GPS sensors. I’ll have to do some extensive testing on this before flying great distances.That’s way better for flight dynamics!
But can you be sure its presence cannot possibly mess with the onboard compass? Or GPS? Because that’s how you lose your aircraft!
I’ll never load anything similar on my bird; the risk/benefit ratio is frightening, in my opinion.
You may intend a short test flight, but a compass error can send your bird rocketing, out of your control, into the distance before your very startled eyes. Have a look at the current "Mavic Air flyaway" thread for one user's experience of compass error. IMHO, the only acceptable potential interference with on-board systems is "zero".You make a very excellent point. My plan was to mount it on the bottom, away from the GPS sensors. I’ll have to do some extensive testing on this before flying great distances. ...
This is exactly where I intend on mounting it, to the battery on the bottom using Velcro tabs.Could the Loc8tor be mounted on the battery using Velcro on each battery. Would it cause less interference there?
It’s the non-gps version, so limited to 400 feet. The idea would be to use Find My Drone to pinpoint the last known gps location and then the Loc8tor to assist from there. I haven’t found any GPS solutions small enough to mount to the air.Is the detection range limited to 400ft or are you using the gps version ?
That does not help GPS error. My GPS showed last location, 1/3 mile from the house. I had hit record and after looking at video and landmarks it recorded landmarks 4.3 miles in the opposite direction in a mountainous area with no trespassing signs. If I had not hit record I've had no idea where to start looking. After uploading records to DGI they replaced under warranty because of an internal error.Just fly the thing. Chances of a fly away, lost drone or any other serious issue are probably increased using anything stuck on like this. After a few flights you will gain confidence and stop mollycoddling your new craft
How has it been doing so far?Started to use my Trackimo with the MA, using this mount the aerodynamics is not too badly affected, only on the point of take-off is there a small side slip until the AC compensates, then it behaves as normal.
The trackimo needs to be raised for propeller clearance underneath it.
How has it been doing overall? Where did you mount it? Does the MA show any difference in performance with it on?I’ve personally decided to go with the Loc8Tor Lite device. It works a little bit differently, but it’s much lighter, and combined with the Find My Drone feature should be enough to easily track down a lost drone.
