This is one of the coolest accessories I have for any of my drones-definitely worth getting.you can buy the 18w charger from dji its the one that comes with the flymore combo and if you had more batteries there is a battery case that holds 3 batteries and charges them one after the other and doubles as a power bank as well
yes but just make sure you use the cable that came with the MMThanks Guys!
So I can use my 18w iPhone 11 Pro fast charger, with usb-c to micro usb cable convertor to fast charge the on board mavic mini battery, Until I get the dedicated hub?
Ps what difference in charge time will this make ?
Thanks
k
you need a cable to carry the higher load if you just use a normal USB to micro usb you wont get the benefit of the higher output i believe,does your iphone charger have a removable cable ,if so just remove that one and use the cable that came with your MM, the combo comes with two cables for the fast charger and they are thicker than a standard USB to micro USB cableThanks you!
The only charging cable with MM
is a normal usb to micro usb. The iPhone fast charger is usb c to lightning .
So do u need to buy a usb c to micro usb so I can use Apple fast charger ?
Thanks
K
i can see what you mean now thanks for info thats different from my ipad charger USB
I don't think the C charger will work for rapid charge. C standard for rapid charge is different than QC for regular USB. As a matter of fact, it puts out as much as 20V in rapid mode so it could possibly damage the MM. MM negotiates 12v with a compatible charger.I guess I can just get a usb c to micro usb cable -and then I can charge MM using the Apple fast charger ..?
Cheers
K
You'll notice a difference in speed of the LED flashes if it's not in rapid charge mode.The charging pack that comes with the Combo is a versatile accessory; charging, storage, size. Today I charged the pack (one battery with 2 lights flashing) to test my portable charging unit. I saw no appreciable difference in charge time, which boosted my confidence for when I take it to the field. Enjoy your flying.
