Mavic air charging
Scalo
Hi, can I charge the battery in a 230 volt outlet with voltage imbelance without something breaks?
Do you mean voltage imbalance? If so, what imbalance are you referring to?
Im not sure, it's in a bus.
I do not know about your situation, but the charger should be able to run from a 230 VAC outlet. You may need to get an adapter for the plug.
Achernar
