Mavic Air Won't start anymore
Jcwww
Düsseldorf, Germany
Problem?
Unit will raise about 3-4 inches, then lean to back and left until rotor hits ground
Was unit in a crash?
While landing, one of the rotors touched a wooden pole while the drone was a couple of inches above the ground. No visible damage.
What have you tried so far?
Replace both back rotors
What device are you using ( iphone , ipad, Samsung , etc)?
IPhone X
What firmware are you running ( aircraft, remote controller)?
Latest as of Sept 16th
What Go app version are you using? 4.3.1
Any modification?
(if so what)
no
Did you change anything or install any apps? (if so what)
Litchi (same result when trying to start)
Do you have a video or pictures of the problem? (if so post link)
no
Any ideas? Seems like the back left motor is slower than the other three.
Ok, someone has to ask & I apologies in advance for insulting your intelligence, but you have put the correct props on the correct motors? Do the props turn freely at rest?
Reactions: Jcwww
Don't worry I'm a total newbie so it's highly likely I do stupid things :)
But yes, they turn freely. BTW, the replacement rotors that came with the fly more combo all looked pretty identical to me
Reactions: pinoydrone
There should be 4 with white marks at the centre hub & 4 without marks, Mavic should have 2 of each fitted on the matching motors. Sorry again if this is a bit obvious.
Reactions: Jcwww
Reactions: Jcwww and JDawg
The props dont actually fit on the wrong motors. You cant lock them without breaking something on the bird or on the prop. Take a really close look at the mounting locks on both the new wrong prop you tried, and the motor this happened on!
Reactions: Jcwww
Well they did - though not as easy as advertised ;) should have been a warning.
Haven't had the opportunity for a test flight yet, way too windy (on holiday atCosta de la Luz, Spain)
If you got the wrong prop on, it had to have broke something. Either the prop, or the mount on the motor, or both.
Reactions: Jcwww
Well the correct props were mounted pretty quickly.
I would still very well inspect both the props and the mounts, maybe even replace them preventively. Given how you have to force to fit the wrong props on it's very likely there is some damage that could cause something to break after a while.
Reactions: Jcwww
jimi79
