Mavic and Spark Case
Was this helpful?
  • Yes
    Votes: 2 100.0%
  • No
    Votes: 0 0.0%
  • Total voters
    2
Trunner
Hey, in case anyone wants a case that will hold a mavic pro and a spark, I thought I should share my design files. Here is the finished product:
If you go to a local maker space, they usually have a laser cutter. Buy some foam pads (see amazon link bellow for an example) for a few dollars a bundle from a dollar store. You will need to laser cut several layers. I used a case from PrincesAuto for $50
Here are the DXF files.
File 1 - This is the bottom layer
File 2 - This is the second layer (Slightly wider in some spots so the parts can sit down inside the foam.)
I hope it comes in handy!
Multiport charger: https://www.amazon.ca/Parallel-Mult...71&sr=8-2-fkmr0&keywords=3+port+mavic+charger
Foam good for tool cutouts: https://www.amazon.ca/ProSource-Exe...=1525751557&sr=1-4&keywords=interlocking+foam
Reactions: Sitruknosnhoj
Nice clamp reminder. I forgot mine once or twice, and got the "giminder" on amazon. Its a nice gimbal lock/protector with a big red ribbon that says dont forget the clamp. Just a suggestion if you dont want the eyesore of the sticker on your battery.
Derek_m
-Ok, cool, I will leave it up.
Skiergd011013
-Yeah I keep thinking about buying that cover, But I use the cam holder to clean the lens before flight.
djiNonMini
