Mavic drifted out of control
I'll have to look at my flight logs however I mean as soon as I lifted off it was drifting. I'm wondering if it has anything to do with the update I just uploaded I mean at even 2 feet it was drifting
That’s exactly what happened to mine. Can anyone please help and tell me how i can read my flight logs?
Seeking help. I flew my Mavic earlier and soon as it launched it drifted quickly to the right without me sending input controls the remote. Here's the link to the flight logs - Log File Scared to fly it right now as it might do the same thing again. Any recommendations on what I need to do?
None of the three DAT files in that log (FLY049, FLY050, FLY051) are actual flights. You need to look at the txt log from your mobile device first. That may or may not include enough data to figure out what happened (quite likely not definitively if it was a magnetic interference issue), but it will include the DAT file record number.
As mentioned above, follow the instructions here to retrieve the txt log: DJI Flight Log Viewer | Phantom Help
Reactions: Mavic Pro Platinum
I found a few other posts about calibrating which I'll try when I get home.
I had made a fix to the Gimbal Vibration Abnormal message and just wanted to see if that was fixed so I wasn't flying for more than a few minutes noticed the drift and when I saw the same question posted I thought hmm wonder if the firmware update had anything to do with it ? hence my post
I'm at work currently and quite frankly to the people with the Please Post your flight logs really aren't helping the situation it's already been stated over and over so relax yourselves. WTF it's supposed to be a community, people post a friggin question because maybe there is an easy answer. I'm sure y'all ain't experts on everything
Does GPS location changing due to additional satellites coming on-line making location corrections make the aircraft veer off like that? I would think it would only affect its RTH and flight records.
maybe when you post all info needed you might get proper response
Reactions: JDawg
Where exactly did you take off? Was is reinforced concrete or steel?
Last December i had compass issues from taking off at reinforced concrete. was able to correct that then. do u think that messed up my compass again? this time i was in the woods.
Thanks for the information regarding how to download flight logs and have the analyzed through DJI Flight Log Viewer. It looks like it's a compass error. Please see link:
First Log
Second Log
It was clearly showing compass errors, and if you compare the IMU data with the GPS data there is obvious disagreement - common for that problem:
Looking at the yaw data, the initial aircraft heading was recorded as 80°. On the ground that looks like the image below - do you recall which direction the aircraft was actually pointing at takeoff?
Taking off from a magnetically compromised location is not going to mess up the compass, it simply initializes the IMU yaw with the wrong value. When the aircraft takes off and the magnetic interference goes away (it's typically very localized - just a few inches), the compass and IMU then disagree - that's the compass error. You shouldn't even need to calibrate the compass - just move to a better location and restart the aircraft.
I'd like to say the aircraft was pointing East at time of takeoff.
Alright guys, let's tone it down a notch or two. The thread has been cleaned as some members here got a little sideways. Let's remember we are here for the same reasons, to learn about these magnificent flying machines. As per the rules, Community Rules, we don't allow name calling, rudeness, etc. Please keep it friendly.​
I suspect that it was not pointing east, because that was close to the initialized yaw value and it would not have generated a compass error. If you want to get the DAT file off the mobile device then we can take a look at the underlying magnetometer data which should unambiguously show what happened.
@gulfrider I can see that you posted your log files - several times. The Dropbox link you provided in your first post contains the .DAT created by the DJI Assistant 2. From that I extracted FLY046.DAT. It shows that the launch site was geomagnetically distorted.
Apparently you didn't provide any throttle until about 12 secs. At that point the MP started to ascend and there was a Yaw/magYaw separation - a clear indication that the launch site was geomagnetically distorted.
Looks like the actually heading at launch was west.
Good spot - I missed that he had posted that one earlier. That is the DAT corresponding to the flight above. 180° offset would be correct for a linear uncontrolled flight.
@gulfrider what's really interesting is that the MP appears to have listed off the ground without any control inputs. It wasn't until 11 secs that throttle was applied. Yet, the MP moved from here
to here
Does that seem about right?
Also, the MP didn't think it was airborne during this interval. This from the eventLog stream
-.356 : 3421 [L-TAKEOFF]alti: -75.748299 tors: 80.761948
.865 : 3482 [L-FLYMODE][Ctrl<2>] REQ_RC_COMMAND ASST_TAKEOFF ctrl_asst_takeoff
12.274 : 4052 [L-FMU/FSM]state changed. cur: in air
That's OK. Since yesterday I was trying to figure out why the MP lifted off without control inputs. Didn't even think about looking at the mag data.
Appears the MP just barely lifted off and then became a victim of it's mag problems.
to here
It looks like auto takeoff, so that presumably explains the absence of throttle.
0x6e08715
