Mavic drops out of sky - crashes - why?
I was working with the aircraft DAT, but they are in both DATs. Slightly different timing data in the tablet DAT:
98.439 : 6883 [L-FMU/FSM]near ground
99.361 : 6929 [L-FMU/MOTOR]safe_near_grd:true
99.464 : 6934 [L-FMU/FSM]not near ground
99.523 : 6937 [L-FDI][CTRL]: fault on , tilt_ctrl_fail
99.540 : 6938 [L-FMU/MOTOR] Stop. reason:roll over or atti fail
99.540 : 6938 [L-FMU/MOTOR]Total start times: 1, time: 99.52
99.541 : 6938 [L-PWM]set actuator mode:IDLE
99.541 : 6938 [L-FLYMODE]CTRL reset all by motor stopped
99.543 : 6938 [L-RC]craft ctrl failed!!!
99.544 : 6938 [L-FMU/FSM]state changed. cur: motor off
99.545 : 6938 [L-FDI][CTRL]: fault off, tilt_ctrl_fail
99.558 : 6939 [L-IMU]set imu switch level = 1
After discovering why I couldn't find these (I didn't select the event log in DatCon), I was wondering, for future reference, if you have a link on what each number means in the event log. Thanks! -CF
The first number, obviously, is the time. The second appears to be some kind of index number for the entry. I've never paid much attention to it. @BudWalker may know more.
Wait, where are you getting the translating words from? My event log only gives the numbers (6883 for example).
That's straight from the DatCon output file.
Bear Cove
