Flight Radar24 for where the Big Boys are.Just got my first drone, the Mavic Mini, can people recommend any apps worth downloading. Thanks.
Pretty sure about that ... it's mainly the same app but coded for 2 different platforms, user result should be the same. The only thing that can happen is that values dialed in through one app & which is stored in the AC will then overwrite values in the other app when that is hooked up (think RTH altitude is one of that kind of value).Does anyone know if one specific DJI Mavic Mini can be controlled, at different times, from BOTH an Android App and an IOS App on different mobiles? i.e alternate control between Android and IOS mobiles with two different pilots.
Haven't a mix of iOS & Android myself, instead 2 android phones & one android tablet for my Mavic Air ... certain values is overwritten when I switch device. Can't imagine that the device mix you present should be a problem ... go ahead & try it out, but take it into your startup procedure to quickly scroll through all settings when you swop devices..
I'm confused about Airmap/Kittyhawk. Since you get authorization inside the DJI Fly app, how does airman/kittyhawk matter or help in terms of authorization? Thanks in advance, I'm new at this...You will need Airpmap or Kittyhawk for LAANC authorization. Either one will work. It's a matter of preference.
I have always gotten clearance from AirMap or FAA DroneZone. I have never asked DJI for permission to fly with any of my drones nor communicated with them regarding flight clearance in any way...., and never had a problem.I'm confused about Airmap/Kittyhawk. Since you get authorization inside the DJI Fly app, how does airman/kittyhawk matter or help in terms of authorization? Thanks in advance, I'm new at this...
