Hi - Pretty new to flying the Mavic Mini and was hoping to get some help analyzing what I did wrong or if there was something wrong with my actual Mavic Mini when I flew it recently. Here's the flight path: DJI Flight Log Viewer - PhantomHelp.com
I launched the drone with 10 satellites, set home point at 300-400 ft altitude to avoid crashing into nearby buildings when it returned, and launched it. Once it reached about 190 feet altitude the distance kept flying in the opposite direction due to high-wing and I was unable to lower it or direct the drone back and the remote controller wouldn’t take the drone back.
Once it was 450 ft away and I couldn't manually fly it back towards me, I set RTH. By then reception started going out with my controller and it kept drifting in opposite direction. Eventually I had zero reception of the drone and I couldn’t see anything around 900 feet. At a certain point I got a notification that it was going to land on its own without my control. I wanted to at least land it somewhere near land if the drone couldn’t return to me but I couldn't override anything. Instead I didn’t get any reception at all and it just landed on its own without my control into the water. I only knew about this when I came home and uploaded the flight path.
I'm going to assume that I made several user errors, including flying the drone in too high of wind, but I really would like to figure out if this was 100% my fault or if there was some internal error with the Mavic Mini as well so I can learn from this experience.
Thank you!
Thank you!
