Mavic Mini gimbal shake
maxmazz
Italy
Hi, on my new Mavic Mini the camera something like an high frequency shake when the tilt of gimball is set around 10°-12°, other angle are perfect also in fast moving footage.
Changed all blades (ESC error on one rear arm after a couple of hours), shake reduce but persist.
Between the critical degrees it's possible to hear a light noise in the gimbal motor.
Some suggestion?
Thank in advance and sorry for my bad english
Are you using any ND filters?
No filter
I made a new test in house without motor on and there is something like an high frequency shake with noise between 8-12 degrees, at any other (+20:-90) it's ok.
I have cleaned the lateral joint of camera with a soft brush and manual air pump of camera lenses and seem to be ok now (no noise). This weekend with permission of the weather I will make a check in flight
Stay Hi Productions
