Mavic Mini Lost Not Returning Home
changkh
Singapore
Hi experts,
After reading numerous Mavic Mini flyaways, today is mine turn to experience it.
Hope I did the right steps but here is the log.
I did went to search for it based on the last location in the DJI Fly App but couldn't find it.
Could any experts advice where it could have landed?
NZ5MKTE8JBZCJIYZ48MQ
I am curious, what happened?
I am not going to attempt predictions based on the flight data (way beyond my capabilities).
However, as I understand the information on that page the drone seems to have responded to an RTH and to be heading straight for the home point with ample battery left.
Zooming in and then opening Google's street view I am wondering if it flew straight into one of the tower blocks, Seahill Tower 2 perhaps. How high above the ground level around Seahill Tower 2 is your take off point?
Reactions: Prismatic
The last recorded location is just where the drone was when signal was blocked by Seahill Tower.
You were flying at the set RTH height of 60 metres when signal was lost.
The drone would have entered RTH soon after and flown toward the home point.
But to get to the home point, it would have tried to fly through the tower.
It's not really a fly-away. It was flying towards home in RTH mode when the log ends.
From the page you shared. 16.9 MPH is about 7.5 M/Sec so it is not having any problems overcoming the wind and if you extend the yellow line it is heading home. If Seahill tower is taller than 60M, I would expect to find the wreckage somewhere near the corner of the tower.
Reactions: Motorcycle Rider
That's what happened:
Reactions: Seagull01
It's 28 floors, so definitely higher than 60 m.
I made a mistake. Forgot to update home point after I moved to the start of the yellow track.
I triggered RTH and was expecting it to fly back straight but it didn't and flew back to where the home point was first updated.
It was only after I uploaded the logs then I realised that it was not a flyaway.
I supposed it hit the building but then the last recorded point still shows the aircraft is at 200 feet.
Anyway, I am going to look for it again now.
When last recorded, the drone was still flying at 8.2 metres/sec and in stable flight.
The data does not record the crash which happened after signal was lost.
Overspeed
