Greatings from Portugal !
On my last flight ( 23/04 ) and after the last update ( V01.00.0500 ), I received a message to repositioning my Antennas, but the bird was really close, analising the data, I can see a lot of losses in the radio signal.
That happened in two different locations , the first one in the left hand side of a bridge and the other on the right hand side... It's a concrete bridge...
Another IMPORTANT and very DISTURBING thing is that in BOTH flights in the .DAT file I can see all the up's and downs of the radio signal but on the .Txt files radio is always 100% even when I received a message to repositioning my antenna on log 063.txt ( weak signal Code: 80016) quite strange that difference between the logs.
PLEASE see how different both logs are related to “radio” signal…
PLEASE use the HD flight player to better see the diferences…
1 - Any idea about that huge lack of radio signal whit the bird flying so close ( even at 1mt away!!! ) ???
2 - In which Log can whe relie on ???
3 - Is this a major issue with this NEW FW UPDATE ???
Yes, I updated Both MM and controller, and I recalibrated it...
Hope to get some answears for this problem...
Thank's in advance
Log TxT 063 :
Log TxT 064 :
Log DAT 063 :
Log DAT 064 :
Thank's in advance
Log TxT 063 :
Log TxT 064 :
Log DAT 063 :
Log DAT 064 :
