Yesterday while flying my mavic mini I lost radio signal and the RC went into return to home. This was my 27th flight with the mini. Soon after I regained video feed and I yawled the drone around videoing while the drone was flying back to me. As it was still aways from home I canceled RTH and started manually flying the drone. All of a sudden the app voice said something about going to ATTI mode. I let off the controls immediately and and noticed I had a Code: 110007 (Battery Communication malfunction. Reinstall battery. If issue persists, replace battery). I also had Code: 30004( Aircraft in Attitude mode. Unable to hover. Fly with caution). Looking at my telemetry I had 0 satellites and my Distance said 0 as well. I could tell by my video feed that the mini was being drifting away by the wind. I was able to fly it back to myself manually but it really makes you appreciate the gps positioning because it was quite a handful even in the light wind.
Another strange occurrence of this flight is the Flight Data Center in my phone broke this into 2 instances. One flying out to the point of signal disconnect and then started a 2nd one for the return flight. If I look the return instance it shows the flight path going across the Atlantic ocean and finally stopping in the Gulf of Guinea! Playing it doesn't show the AC follow that path but shows the blue line there.
After I landed it I shut everything down and restarted and everything seemed fine. I did remove the battery and made sure it was inserted properly because of Code: 110007 that referred to the battery. I flew it around close to me and everything worked as it should.
The only thing I did differently yesterday was I put my phone in airplane mode. I only did this because the day prior I got a phone call during a flight and I saw a post on this forum suggesting to put your phone in airplane mode to keep this from happening. Could this be the reason for going into ATTI mode mid flight?
I ran 3 more batteries thru the mini after this instance without any problems but I kept airplane mode off. I am using a Galaxy s10 phone.
If anyone could explain why this happened I would greatly appreciate it.
