Mavic mini won't connect to anything.
Čuks
Serbia
Regards to all
I have been trying to find a solution on the Internet for two nights, but I just come across the same unanswered question. The drone won't connect to anything. Neither with the controller nor with the computer (dji assistance and device manager). I tried literally everything. Start a computer without a USB signature. SD card formatting, two pieces. Tried without SD card. Five cables, including the original. All batteries charged. I tried pairing both via the FLY app and via remote controls. All I get when I turn on the drone is a quick blink of red / yellow / green twice, then the same five times, then red / green slower as long as it's on. When switched on, perform a standard propeller and gyroscope check. Is there something I missed, before I take it to the service.
Is the battery good, and charged? Have you tried another? Bad battery or contacts could cause similar symptoms. Not enough power to connect to anything.
I tried all 3 batteries fully charged. When drone is off, connection to PC start charging. When is on, nothing happens whilst is connected.
Reactions: OptimaZe
Would say cables but you’ve already tried that. Some cables are ‘charge only’ no data, only reason I would mention it. Was DJI customer service any help? Been helpful to me in the past. IF you get the smart rep
Contacted them but it's weekend so i assume they are on a break. When i connect RC to PC all is normal, assistant recognised it without problem.
Reactions: Capt KO
I have done everything you are stating in OP but can’t get it to connect at all. Weird, one day it works and then doesn’t the nexts day. I tried for 2 hours one day and now another hour down the drain.
I CONNECTED. I unplugged my microsd card, connected right away and then plugged micro sd card back in and voila, worked for me after numerous hours of BS uninstalling software; resetting apps and all that crap! Good Luck.
But you said you already tried that and didnt work…. Right?
Pro-MBS
