thank you! I'll give it a tryNot necessarily so, it may have gone into "deep hibernation".
Search in here for that, or google it, and you will find the process to bring it out of that protective state.
Here, I started for you:
Thank you I charged it overnight and it will not do anything at all now! Guess its just dead!One of my batteries did that when I bought it used from a guy who hadn't flown in a loooong time. Again, I had a (different) battery do this at random recently.
The fix for both was to simply keep the battery on the charger overnight...at some point in the night they got fully charged and I've used both since with no issues.
Yes as much as I could. It would never switch on it would only blink. I left it on the charger overnight and then it wouldn't do anything. Thank you.You did follow this procedure to the letter?
IMPORTANT: DO NOT ALTER THE SEQUENCE OF THESE STEPS!
Or even a full 24 hours....AND using the DJI supplied charging hub.......
- Switch on battery – one quick press followed by a press that lasts 4 seconds. ...
- LEAVE IT ALONE for at least 5 minutes.
- Do NOT touch power button on battery – plug it into your DJI charger.
- LEAVE IT ALONE… it may be hours before it wakes up.
I have the same issue with 2 DJI batteries. They are about 1 yr old with 20 flights. I have a Powerextra purchased at the same time that's fine. All three were charged to 100% about a month ago. I just read the process above and am trying that currently.Yes as much as I could. It would never switch on it would only blink. I left it on the charger overnight and then it wouldn't do anything. Thank you.
