Mavic Pro Battery Mod
I can't believe we are all up still reading and writing on this threat it is 4 o'clock in the morning
Now you feel how it's like, normally im the one being a bat.
I just got done talking to my son in Iraq one reason I'm still up. I have to go by their time not mine.
You have been busy, nice ! Do not wanna spoil the fun but it's possible the front compass will start nagging. It does not like being hugged by powerleads.
Side mounting did not work for me
Side mounting will work. You just need to keep wires from hanging down where the sensors underneath the mavic may sense them. Many of us run batteries on the side.
Let us know if any issues. Maybe not at all, some flights will tell.
Well I took it out for a test flight and it did go into ATTY mode on it's own a couple of times. I don't know if that is because of the mod or something else but I may look at re-routing the cables to get them away from that compass anyway. I don't want to take any chances.
Did you have anything strapped on top covering the gps receiver behind the main battery?
No nothing on the rear. It went back into Atty mode again after I moved the wires even plus it gave me a Compass Error so I Calibrated the compass and all seems to be ok now.
I am make myself and like that digdat0. I leaving bare.. Remove the plastic shell, weight at 30g the plastic shell.
Dji Dual battery mod & 2 x 4000mAh LiHV.
2 x XT60 in wires (- Negative + Positive)
Add to soldered the power pins. (2,3 negative) and (5,6,7 positive +)
20247993_1427697983976372_3610611085364160210_o.jpg 20424169_1427698087309695_1997676331701470202_o.jpg
What kind of run times you getting?
Not yet ouside just rain and windly.. I will ouside long distance the single 4000mAh LiHV and next 5200mAh LiHV. After 2 x 4000mAh. look good updated my post the Dji Dual battery mod & 2 x 4000mAh LiHV well.
Do you normally have to recalibrate the compass if you unplug it from the main board?
Don't know..would not hurt really, just do it!
View attachment 18081 View attachment 18082
Drooool!!!
mariovaleo
