Mavic Pro Battery Mod
Well anyway.....I'll more than likely be trying one of them whenever they hit Jakes place but I'll listen to what you have to say about it first.
This is getting way to much of information and thoughts for anyone not having aspergers.....
60 pages of info fellows. Can I suggest that the ones who have made up the good info here would make summary of what has tested useful and what's turned out to be crap. And when that have been done, it would be awesome if op would update the first post with that info added.
I know im asking you to do work for me. But you'd safe the world probably thousands of valuable hours in the long run. [emoji16]
So keep being way to smart nerds, and add a little need to summarize all this mess you've made. [emoji854][emoji4]
Reactions: Mavman
60 pages of info fellows. Can I suggest that the ones who have made up the good info here would maje summary of what has tested useful and what's turned out to be crap. And when that have been done, it woyld be awesome if op would update the first post with that info added.
I know im asking you to do work for me. But youd safe the world probably thousands of valuable hours in the long run. [emoji16]
So keep being way to smart nerds, and add a little need to summarize all this mess yoyve made. [emoji854][emoji4]
Look, we've made all of this garbage now it's your job to sift thru it! The good stuff is there I promise.
you guys are cute :P
i did a battery faq for the p3, it really did help people .. but its a lot of work. Anything specific you wanna know? I'm lazy atm :P
How do I get air data where do I get that from
I hope I'm not too late [emoji14]
I'm looking forward to seeing distance results with the Titan 7000mah. I'm on a 3 week vacation, so it won't be me. Anyone weigh the 7000 pack? I'm curious if 2 packs will be doable, or perhaps one 7000 combined with a smaller Titan pack. Would be sweet to get a 1 hour flight time flying at 32mph. I think DJ's results are awesome. Hopefully at speed we see similar results.
40 minutes flight gave me 54k feet. 60 minutes would be close to 80k, just like phantom series can do. Would be sweet!
I might end up with the one none working option in those 60pages of goods..... Finish your work you lazy ***....
Lol not being ungreatfull or anything. [emoji23] [emoji23] im not managing to get through this ****.... [emoji3]
Mine comes in Friday. I'll put it through some proper tests this weekend.
Reactions: CyberNate
What do you want to know/what is your aim?
I will not be getting the titan battery. Seller informed it will take weeks to get here instead of the 5-7 days. I will be on vacation as well right at the sea and was hoping to make serious runs but obviously not meant to be. A bit disappointed really.
My end game is actually to make a twist from useful info and make adjustments needed to make it work on inspire 1 pro.
Since i've got 18650 cells in industry level amounts here (i got probably 50+ brandnew Sony VTC4 18650 2100mAh cells, id love to hear if someone have gotten successful with 18650 Batts)
Thats my first questions [emoji16]
The titan battery uses 18650ga cells which are 3500mah rated. They have a much greater capacity than the Sony cells, but lower C rating.
Wouldn't I get away with using 6 sonys in 2x 3 cells wired in series as one 6s like the inspire pack and wired parallel to the original pack.
That would give me 13.800mah and 30Amps (not really since that's the pulse rate that vapers have made as a quite bogus standard) but probably 25 amps....
Or are my calculations as good (bad) as my calculations usually are? [emoji1]
(sorry to bring inspire questions, i coyldnt find anything both useful enough and working on the subject in the inspire forums.
We have to take into account how much fewer are flying inspire affects the forum quite much.... Not that many posts going on there.... At least not compared to here.
Its really the same subject we're talking about.... Just a little adjustment to fit the bird being modded.
Calculations are correct, but not sure if the c rating will be sufficient for inspire.
I've used those bastards on .11 ohm builds on mechanical mods for years.... They're tougher than they look....
Is this statement a guess or a fact? If anything other than fact, I'll have to try don't I?
gauravsaxena
