Mavic Pro Battery Mod
More worried about bending the short coax when plugging in/out.
I will fly the 2x 3000 setup at the same time checking the antenna.
Put one end on the controller before you mount it and then just snap the other end on after you mount the antenna. That way you don't have to bend them.
In my opinion the dual 3000 setup is the best thing I've tried yet. Not too big and not too heavy but gives excellent run time. Thanks to @CyberNate for recommending such a sweet combination!
Reactions: CyberNate
I'm trying to figure this program out this is the data from the 1500mah mad dog lithium polymer
Wow this air data program is amazing it has so much information I am so glad you guys showed me this program let me try to find a 50 minute flight
Can someone tell me how to go to sync flight in my DJI flight log and add it to air data without having to sync all of them
Follow the instructions here for Android or iOS. HD Sync App for Android - Airdata UAV
In short, you'll need to download the HD sync app so that it can sync your logs from DJI go. You can tell HD Sync how many logs to sync but you can't select individuals... If it's within your last 20 flights, just choose to sync last 20.
ETinVT
