Hello.
My name is ray and i`m new to here to get some advise from you.
I have a mavic pro platinum and have an issue.
I found information about FCC mod here, and modified my mavic via super patcher.
It works very well,
Also, I tested my AC and it does work exactly.
After than, I read other information about parameters.
So I decided to mod it again. watch youtube and try it again.
First of all, I did downgrading my AC to FW 01.03.0700 2times via dumldore.
During the downgrade FW first issue come up. with a battery problem.
After finish downgrade FW and I find issue.
battery lights on the middle of two lights (second and third) are very slowly turning off and on.
(repeating 20sec lights on and off shortly and on again)
Also, that battery is out of working.
Aftet that situation, I changed battery and keep doing this.
Because dumldore said that 100% done and update finished.
so, I move on next step.
Install Dji assistant2 1.1.2 and done parameters job.
After finish changing parameters and second issue is come up.
My AC can`t connect with computer. I tried to other PC and other cable as well.
(window usb connecting sounds are on and off continuously)
RC is not connect to AC. and on the setting information say that AC FW is unknown.
therefore, it can`t go for factory settings via Dji assistant.
@Current conditions.
- One battery`s second, third lights are on. (I googled it. it can be fixed with FW upgrade)
- AC seems like running ok when I turn it on. but NO connection with RC, and PC.
(AC starting sound has been changed a bit. It used to has sound like PPPP~~B~B~. but now p~B~B~ )
(When I turn AC off, only first light is blank and turn off time is longer then before. it takes about more then 5sec. )
What should I do in this situration.
Please save me and my dron. I`ll waiting for your any comments.
Thanks a lot From South korea
(Sorry for my terrible English and I hope you guys understand
It works very well,
