- Joined
- Jul 8, 2019
- Messages
- 167
- Reactions
- 89
Problem? The gimbal keeps hitting the end of its pitch spectrum upon startup.
Was unit in a crash? Yes, and I broke the gimbal vibration plate.
What have you tried so far? I replaced the plate and it flew fine for a while. Then I forgot to attach the gimbal lock one time and the case took a nice bump in the road.
What device are you using ( iphone , ipad, Samsung , etc)? iPad Mini 2
What firmware are you running ( aircraft, remote controller)? Latest, both.
What Go app version are you using? DJI GO 4. Latest, I think.
Any modification? (if so what) No.
Did you change anything or install any apps? (if so what) No.
Do you have a video or pictures of the problem? (if so post link) Not right now, but I can post some later if needed.
The gimbal starts to go through its self diagnostics process, right? Then it goes all the way up, then all the way down, quickly. It hits the end of its range of motion both ways, goes up and down a couple more times, then goes limp. On the GO4 app I'm getting messages such as "Gimbal Motor Overload" and "Check to see that the gimbal lock is removed" and "gimbal will restart in a few seconds," or something like that.
I thought maybe it was the vibration plate? Maybe the rubber bands got stretched out when the case went over that bump? I have checked the wires, and from what I can see, none of them seem damaged.
Help???
Thanks in advance! I know there are a lot more people more drone-savvy than me out there!
**Update**
I replaced the vibration board again, and it didn't fix it. I'm thinking I need to replace the ribbon cable, in response to the post below by @mavicpro66.
Help???
**Update**
