Hi,
My Mavic pro crashed on the climbing process. However, the crash seems really weird as there's no obstacle on the way of my flight, the drone just started to spin itself and crash to ground. While checking the wreckage of the plan, I found that the right side arms of the drone are folded!
Could the reason for the crash be related to the defect of the arm to let it fold on air?
There are also some errors in the app log like "GPS Position NoMatch ","battery voltage abnormal" and fatal log in aircraft's log (can be found below): (Most of the critical issues came after the error message below at about 57s after taking off)
There're also some figure and log below:
DJI App log: DJI Flight Log Viewer - PhantomHelp.com
figure from the DAT
folded arm after crashed
(At the time, i was using the "Pix4d Mapper"(3D modeling app) to automated control the drone, and its present is directly climbed to 150M to start the capture.)
Any help would be appreciated!
Code:
57.506 : 39739 [L-FDI][CTRL]: fault on , tilt_ctrl_fail
57.524 : 39740 [L-RC]craft ctrl failed!!!
57.686 : 39748 [L-FDI][CTRL]: fault off, tilt_ctrl_fail
59.545 : 39841 [L-RC]craft ctrl failed!!!
60.083 : 39868 [L-NS] [AHRS] gyro mag inconsist on
60.706 : 39899 [L-FDI][CTRL]: fault on , tilt_ctrl_fail
60.746 : 39901 [L-FDI][CTRL]: fault off, tilt_ctrl_fail
60.906 : 39909 [L-FDI][CTRL]: fault on , tilt_ctrl_fail
61.026 : 39915 [L-FDI][CTRL]: fault on , height_ctrl_fail
61.046 : 39916 [L-FDI][CTRL]: fault off, tilt_ctrl_fail
61.085 : 39918 [L-FDI][CTRL]: fault on , tilt_ctrl_fail
61.564 : 39942 [L-RC]craft ctrl failed!!!
63.584 : 40043 [L-RC]craft ctrl failed!!!
64.386 : 40083 [L-FDI][CTRL]: fault off, tilt_ctrl_fail
64.546 : 40091 [L-FDI][CTRL]: fault on , tilt_ctrl_fail
64.646 : 40096 [L-FDI][CTRL]: fault off, tilt_ctrl_fail
65.605 : 40144 [L-RC]craft ctrl failed!!!
65.925 : 40160 [L-FLYMODE][Ctrl<1>] REQ_RC_NORMAL ATTI_HOLD ctrl_gps_atti
66.446 : 40186 [L-FDI][CTRL]: fault off, head_ctrl_fail
66.986 : 40213 [L-FDI][CTRL]: fault on , head_ctrl_fail
67.046 : 40216 [L-FDI][CTRL]: fault off, head_ctrl_fail
67.286 : 40228 [L-FDI][CTRL]: fault on , head_ctrl_fail
67.406 : 40234 [L-FDI][CTRL]: fault off, head_ctrl_fail
67.624 : 40245 [L-RC]craft ctrl failed!!!
67.666 : 40247 [L-FDI][CTRL]: fault on , head_ctrl_fail
68.059 : 40266 [L-MIS]WP Mission: received idle vel cmd 10.000000 from app
68.060 : 40266 [L-MIS]WP Mission: ack idle vel 234 to app
68.746 : 40301 [L-FDI][CTRL]: fault off, head_ctrl_fail
69.006 : 40314 [L-FDI][CTRL]: fault on , head_ctrl_fail
figure from the DAT
