Mavic wont fly strait and gimbal pan
Bluecube
About a week ago my Mavic started having problems with both the gimbal and it not flying strait. any time you push the stick forward it sort of veers off to the left a bit and you have to compensate by pushing the sick a small bit right. as for the gimbal anytime the drone is hovering of stationary the gimbal will slowly pan to the side. i feel like these two problems are related and i have tried everything from all calibrations to factory resets. It has also never crashed and props are fine.
Any ideas?
Try calibrating your controller and see if that helps.
thanks for the advice unfortunately ive tried that a few times along with the IMU,compass and gimbal
yeah it is still under warranty so and it seems to be getting worse so i am considering sending it back for fixing.
here is the gimbal drift issue i was talking about. I cant tell if it is normal of not as i haven't flown m mavic in a while and i dont remember it doing that before.
RobertCNewman
