Hello Guys,
The max tilt is set to 35 in sport mode. It is allowed/rexommended to set it to a higher number (35+)? What does it do? I assume that is allows a higher flight speed, does it?
Thanks!
Br,
István
There is a thread on this:
Tilt and maximum flight speed
Does anyone have insight how the tilt value correlates to speed? I set the tilt_atti_range to 60, the maximum allowed. Interestingly, maintaining this tilt throughout a flight definitely does not result in maximum achievable velocity. In fact, it seems backing off on the throttle by about 20%...mavicpilots.com
60 degrees to 80 degrees is the angle you are looking for... good luck!
If you are flying at 60 to 80 degrees, you will be traveling much faster than any back wind, unless you are flying in a tornado/hurricane...Thanks! 60-80? Uhm, seems unsafe for me. A stronger back wind gust can flip the drone...
I set it to 60 (max allowed) I did not manage to fly faster than 73Km/h. Any idea how to fly over 80?If you are at 60 to 80 degrees, you will be traveling much faster that any back wind, unless you are flying in
You have probably reached the max it is capable of. The Mavic 2's weren't designed for speed but for long flight times and quieter prop noise. To go faster would require different motors and props and would reduce your overall flight time. I don't think the arms would endure stronger motors and props without possible damage (not to mention the esc's). Everything was designed with just enough strength to keep the weight as low as possible, again for longer flights.I set it to 60 (max allowed) I did not manage to fly faster than 73Km/h. Any idea how to fly over 80?
