Measuring the reflected temperature using M3T and Thermal Analysis Tool 3
Haraldur
Reykjavik
I am using Thermal Analysis Tool v 3.2.1 for analysing thermal images from M3T. I want to measure the ambient reflected temperature by using the temperature reading off a crumpled aluminum, a standard method for that. Simply, when emissivity is set equal to one (e=1) then the temperature reading should not be affected by the set reflected temperature in the software. This works properly for images from ZH20T but apparently not for images from M3T. Does anyone have any suggestions what may be the issue for M3T?
Haraldur
Haraldur
I think it's DJI analysis tool issue... I tried with another software. If emissivity is 1, reflected temp doesn't affect temperature readings, while using DJI tool, it does...
FatAlbert
