Thinking about getting the
MINI 2 for the 10km range cause of Ocusync 2.0.
mavicpilots.com
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Find out what you need to know and do when you fly drones or model aircraft in the UK
register-drones.caa.co.uk
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
Learn and download
DJI Mini 2 related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
