Multiple battery charger.
Our upgraded chargers are almost here! Doing some final tests! Comes with an on off switch as well :)
Upgraded in what way? I mean, what’s different other than the inclusion of the power switch? And when these become available how will we distinguish the new upgraded version from the previous version when shopping on amazon?
Just comparing the data label from the photo of the upgraded version to the photo in the first post, the model numbers appear the same, but the output current of the upgraded version seams lower, at 12A and 1A respectively for the battery and USB outputs vs the 13.5A and 2A listed on the original. Is that correct?
We will update our listing on Amazon when the new ones arrive - the internals have been changed - the main goal was to reduce the heat - some changes internally as well as adding a power switch!
I hope not. That would be short-changing the charge time.
The max A that the batteries will draw for the shortest charge time is 4.5A. That x3 is 13.5A.
Anything less and your charge time goes up.
DJI short changed us with the stock charger.
Stay Hi Productions
