F
Need help in unscrewing propeller
REPLY
Ignore threadJump to newWatch
A
JoinedJan 15, 2021Messages2Reactions0Age31Location
Dublin
Hello guys!
I'm new here! I was unscrewing the propellers on my
mini 2(was packing for an overseas trip). I could unscrew all but the rear left one doesn't turn a bit. The screw head started wearing off. Any tips on unscrewing this one?
Thanks in advance!
Like Reply
Report
Sort by date Sort by votes
P
JoinedJul 24, 2019Messages2,281Reactions1,704Age50
To be honest I wouldn't even consider removing the props for transportation for two reasons
1) It's not designed for this and you will almost certainly loose some thread locking compound. At a guess, as with the MM, you are meant to use new screws whenever you replace a pair of prop blades.
2) given how tiny the screws are I am very wary (scared) of cross threading them when refitting them.
That said you are probably committed now, the big problem is how due you exert enough force down the axis of the screwdriver to stop it ramping out of the cross head whilst not possibly damaging the motor or the drone's arms. Does the screwdriver have a hexagon on its handle such that you could fit a spanner to it?
One bizarre thing that has occasionally worked for me in connection with a screw with a damaged cross is to try tightening screw by the tiniest amount to see if you can break the stiction holding it. Tightening should be making the screwdriver engage with undamaged flanks of the cross.
Is the screwdiver's cross still in good shape?
I have one idea but it would entail sacrificing the props to expose the screw i.e. cut away the prop hubs and then use pliers or a vice to grip and loosen the screws one at a time .
BUT BEFORE you try that wait and see if any one screams
blue murder about having steel tools near the motor rotor. I honestly have no idea if it would be detrimental to the rotor's magnetism.
You would also need to tape over any and all opens around the motor to prevent debris getting it.
Reactions:
B52-D
Like Reply
Report
Upvote0
Downvote
A
Dublin
Thanks so much for the reply! Im traveling right now. I just got the drone two days back. I have to take a good look at how the propellers are mounted to get exactly what you suggested. And I guess the screwdriver's still got it good. I would definitely try the tightening idea within limits.
I could only agree to those two reasons not to remove the propellers. I read about how it's tightened using some threadlock. However the youtube video I saw made me think it's gonna be an easy job.
Thanks again! Will let you know if I could get it out.
Like Reply
Report
Upvote0
Downvote
P
It's just the slightest of tightenings once it moves, if it moves, that should be enough.
Like Reply
Report
Upvote0
Downvote
P
One other solution has just come to mind, it is probably safer and better than the previous method.
I assume the screws unscrew anti clockwise, if so put the blades in the position shown in the attached. 'Jam' or lock the a blade's hub to its screw then turn the blade anti clockwise.
Methods of jamming, small slivers of wood (from say matches) jammed down between the outer edge of the screw's head and the inside of the hub. The gap may be too small for that to work. If that proves to be the case then place a small, note small, bead of glue over the above gap, (small because you do not want the glue to penetrate so far the it reaches the motor's rotor) and allow it to sink into the above gap or work it into the gap, then let it set.
It might grip the plastic of the blade hub and the metal of the screw enough such that turning the blade anti clockwise will break the screws' stiction.
Try the wood sliver first because it is possible you can, once the screw is loose, remove the slivers and unscrew the screw via normal means. If you end up gluing and the gluing works, I doubt you would be able to free the blade from the screw so cut one blade off at its hub/root then unscrew that screw. That should leave the remaining blade room to swing in complete circles.
Writing that also brought to mind a variation on the method of post #2. It depends on how strong the plastic of the blade hub is but if it is not ridiculously strong it might be possible to crush the hub to the screw with molegrips/visegrips or appropriate pliers such that the hub grips the screw enough to turn the molegrips etc anti clockwise and break the stiction. If so you could then unscrew the screw using the screwdriver.
Again I would wait and see into anyone complains about using steel tools near the rotor.
If you use the latter method I would consider the blades scrap.
![20210116_110857 for screw removal.jpg 20210116_110857 for screw removal.jpg](https://mavicpilots.com/data/attachments/121/121808-84edacc9733a96dad08a0c4136c732e4.jpg)
Like Reply
Report
Upvote0
Downvote
F
I almost did the same thing but b4 I reamed it out i got me a nice quality one. Look for one that has 3 detachable heads with 3 different size. Mini philip heads... take that one with you so you can match up the size.mthose ones they suck
JoinedMar 28, 2020Messages59Reactions0Age54Location
Va Beach Va
