new to drones would like meet and see drones in use
Welcome from the Hampton Roads area of Virginia, USA.
@MA2 317 has already given you the Heads up to the Member's Map and your legal requirments, I'll just say be sure to use it, you might find some new flying friends.
mavicpilots.com
Also, in the "Local and Regional Discussions" sub-Forum, there is the lots of even more information and lists of good places to fly in your area in the "US - Arizona" sub-sub-forum… Be Sure to check it out.
Since you live in Arizona, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Let us know what Drone you are flying and we might be ablet o hook you up with some great links…
Happy Droning…
